I have a 99 Monaco Windsor with a 330 Cummins, side radiator. Dash heater is not blowing any air IF there is any heat. Is there a fuse for the fan if and if so, where is it located? HELP. Jim
In addition to the fuse for the fan, there is a resistor block assembly that is used to give you different fan speeds. If that fails, you can end up with no fan, or only some of the fan speeds.
