bluwtr49
Dec 20, 2014Explorer II
I'm not sure which Aqua Hot you have but on my (much older) unit there are separate valves and pumps for each zone. These are under the cover and if your's are shut off...yep not heat. While you are looking at the valves you could also see if the pumps are running and feel if the lines for the air handlers are hot.
Has it ever worked for you???
38,767 PostsLatest Activity: Mar 01, 2026
