bobman
Dec 20, 2014Explorer
there has to be a pump to move the heated fluid in the resevoir ( is the fluid level correct) from the heat exchanger and if its running I would next find the zone valves and determine if they are opening. If they aren't opening I would see if the thermostat is sending a signal
I am just guessing I've never seen an aqua hot system
38,767 PostsLatest Activity: Mar 01, 2026
