Ivylog
Dec 20, 2014Explorer III
X3 on stuck check valve... tapping on them will usually fix. Can you get heat out of the bedroom and bath zones? If so run them and the dash heat to stay warm until you get home and then worry about getting the front to work.
We did not mention the learn curve on these things can be a challenge. Did not want to scare you and hopefully the multiplex system will not give you problems. In a year you'll look back and say... that wasn't so bad.:B
38,767 PostsLatest Activity: Mar 01, 2026
