dougrainer
Dec 20, 2014Nomad
Ivylog wrote:
X3 on stuck check valve... tapping on them will usually fix. Can you get heat out of the bedroom and bath zones? If so run them and the dash heat to stay warm until you get home and then worry about getting the front to work.
We did not mention the learn curve on these things can be a challenge. Did not want to scare you and hopefully the multiplex system will not give you problems. In a year you'll look back and say... that wasn't so bad.:B
This is a common problem on Aqua hot units. To stop the problem it is best to run the furnace zones for a few minutes once a month. This keeps the Zone check valves from sticking. Doug
38,767 PostsLatest Activity: Mar 01, 2026
