StuartT
Dec 20, 2014Explorer
Just pulled into a WalMart so before I crash, let me try and answer some of these questions. First, I am headed to El Mirage so if I don't get this solved on the road, I will call Roger. In the meantime, I am using the genset to run the heatpumps for heat, so am not cold, just adding hours to the generator. The dash heat off the engine helps in the middle of the day, but driving in the evening/nighttime, it just doesn't put out enough heat to satisfy the cabin.
I just look at the thermostat again. Here are the stations.
Zone 1: Front area from dash outlets and galley from undercounter fans/radiators. Front fan controlled by the thermostat setting, the galley fans by a switch in the galley. Both fan groups work, but no heat.
Zone 2: Not assigned to furnace
Zone 3: Bath/Bedroom. Fan controlled by thermostat and runs, but no heat.
Zone 4: Basement. Have not looked to see what is happening there yet.
Did the paper clip reset but no help.
Ivylog, multiplex system is new to me but I am getting used to it. No problems with it so far.
Crash time!
Crash time!
38,767 PostsLatest Activity: Mar 01, 2026
