Folks, A few days ago I went out to start the generator on my '96 Itasca Suncruiser for just it's regular monthly warmup when I noticed that I had no DC cabin power. This is all of a sudden. For mont...
Check the voltage at the generators starter solenoid. Check both the battery side and the starter motor side. Could be a bad solenoid. Also check for ground cables from generator to the mounting tray of the generator. And mounting tray to frame of vehicle. If possible have a load test done at the starter solenoid battery terminal. Could have a bad connection or cable going to generator.
