Lobstah
Jul 09, 2013Explorer
Cruisemaster1975 wrote:
My batteries are not charging while iam plugged in.they charge fine while motorhome running,and when generator running any ideas?
something odd there. Defintely sounds like your converter is bad if it's only putting out 9V, BUT...when you're genset is running, it should be working the same as when plugged in, meaning the genset is powering the converter which would charge the batts.
So if the converter only puts out 9V on shore power, it should only put out 9V w/gennie running.
Jim
38,766 PostsLatest Activity: Jan 10, 2026
