- MountainAir05Explorer IILocate and remove the large IGN fuse from the underhood fuse block.
- sch911ExplorerIf you are required to leave the key on during towing there may be fuses that can be removed to reduce the draw. Check the OM under recreational towing. Or, you could add a charge line from the MH to the car to keep the battery up. That's what we did...
38,766 PostsLatest Activity: Jan 10, 2026
