You definitely DO NOT want to enter the trucker's diesel lanes from the wrong direction. They will block you in and make you back out of the lanes. What you need to do is go to Tractor Supply or some such and purchase a 5 gallon blue plastic kerosene container. Then when you are in the lane getting fuel you can put 2 or 3 gallons of DEF in the container to add to your tank later. Your idea of using the DEF hose from the lane next to you MIGHT work, I've done it, as long as the DEF hose is long enough, most are NOT, especially Flying J/ Pilot.
I use the 5 gallon container, usually buying 3 gallons at a time and add to the DEF tank when parked. After 3 or 4 diesel purchases the DEF tank is full.
