Ivylog
Jan 04, 2015Explorer III
"THAT tells me that in that particular campground, there are only TWO spaces that are suitable for big rigs, but 18 spaces where one will not fit!"
Actually that does not mean there are only two spaces for big rigs as you said "guys like me really like the big ones for all the extra room" even though you know they are at a premium for bigger rigs... THANKS
OP, before replacing the lights and TVs with LED and heavy internet use I had to run my generator three hours/day to keep my batteries up. Now with 200 watts solar and 800 amp/hour of batteries it takes less than two hours with a Inverter/charger that will not put out 70 amps it's rated 100 amps when on the generator. If I decide to go with a home refer I'll split my battery bank and add another PSW inverter/charger for it which will reduce my charge time even more.
Mr. Mark is correct that you start running out of space for a lot of solar.
