ncrowley's avatar
ncrowley
Explorer II
Feb 06, 2015
Details for Clear Coat Repair
I have areas where the clear coat is coming off. I got a quote for $3K to repair and it is more than I want to spend right now. I would like to try and repair a small area and see how it goes. I have read that others have done this with varying degrees of success.
Questions:
What is the "best" clear coat to get? Should I get a spray or brush on? What exact brand/type do I get?
When you are using sand paper, I assume you go around the edges until you have gotten into a solid area. What type of sand paper? How do you do this so you do not sand off the paint?
How do you clean the area before you put on the clear coat?
Anything else I should know before attempting this?
