zman-az
May 01, 2013Explorer
Most hitches come in 5,000 or 10,000 rating. Then you have to factor the towing capacity of the RV's Driveline. Use the lowest rating to be legal.
There is also the capacity of the actual frame (which may have been modified by the RV mfg) on the RV which should always be above the hitch rating. So if the driveline can handle 10,000 lbs but the hitch is at 5,000 you better not replace the hitch without addressing the frame.
38,782 PostsLatest Activity: Sep 18, 2026
