23hotrodrExplorerOct 08, 2014Dex-CoolFor all of you with a GM 8.1L engine, do you still use Dex-Cool, or have you switched to standard Long Life anti-freeze in the cooling system?
rgatijnet1Explorer IIIOct 08, 2014If it has never had the coolant changed, it is overdue, which may explain the scum that you see. The Workhorse owners manual calls for Dex-Cool to be used. It does not specify an alternative. Anything else that you use is your choice.
Related Contentchanging coolant on 2007 2500HDRe: Dexcool vs. Universal coolantRe: 2007 GMC 2500HD HEATER CORE PROBLEMS!! helpRe: Great cooling system on them there SilverAdos!Re: Engine Coolant Question 2001 Winnebago
