Tom_Barb
Oct 30, 2018Explorer II
Culprit found..
No continuity to ground at the ground post of the Bi-Directional Isolator. Wire was on the post, and tight, found other end not connected to battery negative post.
Next test,, deplete the house batteries o 12 volts, by disconnecting the 50 amp cord, and running appliances.
start engine, and see if it will charge the house battery.
