Dale_Traveling
Feb 10, 2017Explorer II
SGTJOE wrote:I'm pretty much in the same school of thought as MrWizard. Tape straight lines while caulking round openings. I've taped the front and rear cap to roof seam along with skylights and vents. Never have to renew the seal again.
Anyone have pictures of their roof seams sealed with eternabond tape? If I do the tape should I try to do it in one length or in pieces?
Edit: Forgot to mention, one long single piece of tape front and back cap seal along with the vents, shower sky light and a retrofit Jack TV antenna base. If you rework a long run such as the front or rear seal measure and mark reference lines to follow with the edge of the tape. Once down the possibility of successfully pulling off and resetting Eternabond is pretty remote if your a bit off following a seam. A chalk line or tick marks every couple of inches will keep you going in a straight line.
38,780 PostsLatest Activity: Aug 05, 2026
