kmb1966's avatar
kmb1966
Did CHF. Ride is better. Wheels off the ground when leveling
A few weeks ago, I did the cheap handling fix (CHF). Yes I can see an improvement in the handling of my F53. But now when I level the motorhome, my front wheels are slightly off the ground. Is this a problem? They are not really high off the ground but they are just enough off the ground to turn the tire by hand.
I've never had that happen before, and if it is a problem, I suppose I could change to using leveling blocks instead of the HWH levelers. My site is not super unlevel so I was a little surprised when I looked at the front tires and saw they were technically lifted off the concrete pad.
  • kmb1966 wrote:
    georgelesley wrote:
    I have also done the CHF. I cannot see how doing it would cause any change in the front wheels being on or off the ground. If you use auto level perhaps it needs recalibration. I now manually level because I noticed the auto level did lift the MH higher on all jacks than necessary.
    Having the front wheels off the ground is no problem but never either of the rear wheels. Both rear wheels must be on the ground for the parking brake and transmission park gear to work.
    Yes, it does ride with less sway when trucks pass, sudden wind gusts etc. Some say the ride is a bit harsher, we did not notice any change
    IMHO the best improvement for the money is the CHF which is free or close to it. The next improvement is a rear track bar. It will fix the rear end tail wagging syndrome and make steering much, much easier with far less back and forth corrections needed. Cost about $500-600. I installed ours myself. Some make their own for $150 or so, I was not that brave.
    Could you tell me which Rear Track bar you purchased and installed yourself? I'd like to give that a try if it isn't too difficult.
    Thanks for the feedback on the CHF and front wheels.
    I got mine from Henderson suspension in Eugene, OR if I remember correctly. Same thing as the Blue OX, but about $100 cheaper. I did it myself, having a helper to hold the bolt while you torque it would help. You need a 150lb torque wrench and some large sockets, I don't remember what size, fortunately rummaging around the tool box I found them.
  • Effy's avatar
    Effy
    Explorer II
    Can't see how there is any correlation of the CHF and wheels being off the ground when leveling other than coincidence. It does not change the travel of the suspension, it just changes the resistance. And no, having fronts off the ground is not an issue. All that said, I never use the auto level function. It does some weird stuff including lifting wheels off the ground when they don't really need to be. I use manual mode to level. Same result with less drama. My auto level was causing some major body twist and I really don't understand why it does what it does sometimes. I can level in half the time with less frame stress doing it manually.
  • I have also done the CHF. I cannot see how doing it would cause any change in the front wheels being on or off the ground. If you use auto level perhaps it needs recalibration. I now manually level because I noticed the auto level did lift the MH higher on all jacks than necessary.
  • Front wheels off the ground is not a problem. Blocks can be used if you wish. The important thing is not to have the rear wheels off the ground.
