j-d
May 18, 2014Explorer II
I just looked your "van" (as simply G3500, no mention of RV/Cutaway) on RockAuto.com which has very good pricing till you get to shipping cost. Anyhow, the ACDelco part numbers I found in Amazon matched Rock so I'm feeling a little better about the lookup. What neither site says is if the bushings are rubber or poly. Some of the numbers from other brands specify the harder material.
You can use Rock to get Moog numbers. Moog is a very popular brand and other product lines either re-box Moog products or use all or part of the Moog number.
Yes, AutoZone has a lot of those parts. I just looked them up. Add your vehicle, then Replacement Parts, then Steering and Suspension. From there, look at the two subcategories beginning in "Sway." Be sure you're looking at FRONT, and there are still Diameter choices. The prices are about the same as Amazon and you can go to Autozone and match them for fit. Might be the way to go. Shoot, carry the whole Bar in, Bushings, Brackets, Links and All.
38,766 PostsLatest Activity: Jan 10, 2026
