1995brave
Sep 19, 2013Nomad
Check the oil pressure switch. The fuel pump relay only closes to start the engine, when the oil pressure builds the relay is turned off. The oil pressure switch controls the pump from that point on. If you loose oil pressure the fuel pump shuts off.
38,782 PostsLatest Activity: Aug 31, 2026
