Busskipper
Sep 20, 2013Explorer
SpinRite wrote:
Welcome, Leah,
I know this has been a disheartening beginning for your family.
Keep in mind that your RV is just a truck carrying a house around on its back. If the truck portion needs repair, you will likely be better off dealing with a truck repair place or an independent mechanic who is familiar with your year and brand of truck, rather than the RV place (which is more familiar with the 'house' portion.)
Try looking in your local CraigsList or Yelp! to find the right mechanic or truck service shop.
Also, there has been a bit of confusion over the terms "starting" and "turning over." These simple words each carry a large amount of diagnostic information and reversing their usage causes a lot of consternation in the listener.
When you turn the ignition key to 'start,' the electrical starter motor engages and begins turning the gasoline engine; this is called "cranking" or "turning over." If this works OK, it means that the battery and starter circuitry is functioning.
The main motor may "try to start" or "kick" or "fire" but still not "catch" or turn on its own without the starter. This also gives the mechanic a lot of info.
Finally, when the engine does "run," the starter is no longer needed and is released. Even if its not running properly yet, the possible causes of the problem has been greatly reduced.
Best wishes for a speedy recovery for your rig.
The only thing I might add is that in both my Breakdowns, on the road, that I was unable to repair, they happened in your state and the TRUCK mechanics we had do the service, one on the Highway one in a shop were both exceptionally well versed in TRUCKS and the price was extremely fair.
Keep your chin up you will find the issue and once you get on the road a whole new world awaits.
BOL,
38,782 PostsLatest Activity: Aug 31, 2026
