1995brave
Sep 21, 2013Nomad
It is a full 12 volts. On the fuel pump relay just jumper the Orange (12volts) and Gray (fuel pump) wires together to turn on the fuel pump.
If it works, you might want to check out the oil pressure switch (front drivers side of engine). The 10 amp ECM-BAT fuse runs the ECM and fuel pump.
38,782 PostsLatest Activity: Aug 31, 2026
