bshpilot
Jul 21, 2014Explorer
Our coach is the same size as a pusher - 13 feet high & up to 45 feet long.
We are air ride & air brake equipped and SMOOTH as any pusher.
NO Commercial Licenses is required.
Our chassis & frame are PURPOSE built - CLASS & truck frames, not modified like some pushers.
Our 12 speed (some have 13) transmission is a "smart shift" (no TORQUE converter)...no clutch pedal !
Some newer units are coming w/ Allison Automatics (torque converter).
Pushers are inherently more quiet going down the road - engine in the rear, driver up front...
at night the generator is up front & you sleep in the back...that being said our coach (pictured)
is not very noisy (driving down the road)....turbo whine & wind noise are the biggest sources for noise.
IMO (w/ bias) the service rates are better on a front engined coach like ours....engine access can be done w/out entering the coach or bedroom.
our 13.8L 450hp engine does not come at a premium (price) like you would pay for in a pusher.
again w/ bias I believe our transmission is built stronger (capable of handling 650hp and 80k lbs GCWR)
We typically get better mpg than most pushers at the same speed (9.9 at 72mph towing as configured in the picture w/ the generator running)....ive never had any problems pulling any mountain grade and typically do so in the left lane passing most.
we've seen a best of about 13.4 mpg and a worst of 8.9 (generator running) - both were as a result of my right foot pressure on the floor.
Coaches like ours, when equipped, w/ a 2nd axle are not single tire axles nor are they TAG....the 2nd rear axle is a are DRIVEN w/ on demand capability of locking both rear diffs independently of each other as well as locking both diff's together (if you need the full traction of 8 tires & "4 wheel drive").
In a front end accident, i believe our coach will be much safer.
Coaches like ours referred to by some as Truck Conversions & some claim they don't really fall into the SUPER C category (like f550/f650 or GMC TopKick - think jayco seneca).
We have full basement storage but rarely do our type have full pass thru storage bays (unless its in the rear bays, behind the axles).
All conversion trucks have AIR RIDE seats (only high end pushers offer that & usually only for the pilot/driver).
HaulMark, Renegade, ShowHauler and few others make some VERY nice stuff - as luxurious and expensive as any pusher....if you care.
We have capacity for 210g of fresh water - generally pushers do not have capacity for as much fresh water.
Our (10kw) generator is in the rear under the bed (on the driver/road side) we get a slight vibration when its running, Ive seen others where the generator is up front, mid ship or all the way up slightly behind the driver side cab).
All the builders offer optional (motor garage) type coaches w/ a rear garages w/ lift gates anywhere from a couple of feet up to 12+ feet (I've seen cars inside the back of some)...or you can have a full house/motorcoach (like ours) w/out garage.
I recently saw a 45 footer like ours that had lift INSIDE the garage (more commonly referred to as a STACKER garage)....i guess motorcycles on top and/or bottom w/ a car or something.
