- Executive45Explorer III.
- Executive45Explorer IIIDiesel in Phoenix is $3.57/gal as of midnight 7/30/2013.
Diesel in Salt Lake City is $3.79/gal as of 7PM 7/29/2013.
Other cities may be higher or lower...here in Michigan it's $4.29/gal..:E:E....Dennis - zman-azExplorerWhat part of AZ. Around Tucson fuel is way cheaper than Flagstaff. In the res area I have found parts of UT cheaper than AZ. All depends on the city. When I refuel going to/from Moab UT, I will fill up at White Mesa, UT, wide open station with good prices. Cross into AZ and Keyenta will gouge you. Have not done this route in over a year so anything could have changed.
Gasoline is another story as SE UT does not have (or hard to find) 87 octane. - Dennis_M_MExplorerI use FindFuelStops.com to plan our stops. With a 2,500 mile range I fill up where the price is best.
- 1711tabExplorer
Cabo Paul wrote:
Does anyone know if Diesel cost less in AZ vs UT? Thank you.
$3.59 here in Arizona today...
Tim - Cabo_PaulExplorerThank you. AZ is cheaper.
- wny_pat1Explorer IIArizona according to http://www.truckmiles.com/FuelPrices.asp
- HelimechExplorergo to gasbuddy.com
- rr2254545ExplorerTry gasbuddy
38,783 PostsLatest Activity: Sep 09, 2026
