teeznuExplorerNov 12, 2013Diesel Engine heater block-Yes or NoWhat's your thought. In cold weather (below freezing) is it a good idea to keep the engine block heater "ON" or "off" if the coach is just setting and the engine will not be started anytime soon? Th...Show More
Blaster_ManExplorerNov 12, 2013Off unless you are going to use it. I have a timer I set for AM departures. It is set to come on about four hours prior.
Related ContentNear engine overheating gaugePotential engine overheatingDiesel engines.These unreliable new diesel engines!Diesel Engine
