wolfe10
Jul 18, 2014Explorer
Crespro wrote:wolfe10 wrote:
Actually HP alone does not answer the question.
There are Cummins B's with 300 HP and 6XX lb-ft torque
There are Cat 3126's with 300 HP and 860 lb-ft torque
There are Cummins C's with 300 HP and 960 lb-ft of torque
They are NOT the same.
The other part of the equation is loaded coach weight with toad.
The torque/HP question arises periodically. My question is: do all of these engines produce rated torque at the typical 1,600 RPM? What is the difference in the torque/RPM curves?
The larger the engine (actually, the longer the stroke), the lower RPM for peak torque. So, peak torque could be at 1100 RPM or 1800 RPM.
38,771 PostsLatest Activity: Apr 15, 2026
