san elijo kb wrote:
1997 Monaco dynasty 8.3 cummins diesel will turn over fine but will not start.Tried rear remote start switch. Still nothing. I got a can of starting fluid and she would start with that and stay running for 15 minutes until I shut it down . Tried a couple hours later and started right up. This morning same thing , turns over but will not start. Obviously a fuel issue. Must be losing its prime some how or fuel pressure. I'm in So Cal 65 degrees.No fuel leaks that I can see. I'm assuming fuel pump and solenoid are good if it starts and stays running with starting fluid . Will check back later . thanks kb
I thought I read somewhere that using starting fluid on a Diesel, was a no, no....
