jarbra15's avatar
jarbra15
Diesel vs Gas
I'm thinking of buying a Class A motorhome and I am debating gas vs diesel. Just wondering the pros and cons. Mileage differences? Cost of maintenance? Advantages of one over another? Thanks for your input in advance.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    Ok Gas or Diesel.
    Gasoline powered are generally less expensive both up front and to repair (engine/drive train repairs) however Most gassers are front engine and most diesels are pushers,. this has a serious effect on how noisy the ride (The rear engine is not as loud).
    Diesels have a reputation for LONG LIFE
    And more torque at lower RPM (Can be useful when the light turns green or going up a mountain road)
    There are some other differences as well.
    I'm trained on gasoline engine repair so most minor work I can do myself. THus I picked a gasser,
  • Depends on your needs. We started with a gas MH because we could store it in our back yard. Jumping from a truck and trailer we weren't sure we would be happy with a motorhome, a gaser is cheaper to start with.
    However after a few years, gaining confidence we realized a DP would be a better choice.
    We figured out the storage issue, and realized we love having a motorhome. We found a local shop for all mechanical needs.
    The rear diesel keeps ALL the engine noise in the back, 30 plus feet away, no more shouting at each other. The air ride removes most of jostling and noise from the road expansion joints and such.
    It's quiet, smooth and the mpg is better than the gas. With gas we ranged between 5 to 8 mpg depending on wind, hills and speed, I drive the speed limit. The diesel averages 7.9 to 8.5 under the same conditions.
    We have no regrets. Good luck with your decision!
