vegasfoodguy wrote:
bluwtr49 wrote:
Since the question was what are the advantages of each....it made me stop and think. The only advantage of an LP genset that comes to mind is that they are cheaper to buy and perhaps a tad lighter.
On every other front, diesel has the advantage included when time come to resell the coach, no many buyers want LP gennys so that could be a huge problem.
If you find a plan you like, I wouldn't let the generator be a deal breaker. I have LPG, I carry 60 gallons of propane, Diesel is $4.00 gal, Propane is $2.59
Both are readily available. 2 weeks at Quartzsite, my refer used about the same as generator. You don't need to run it that much. I use my inveter as well.
Hope this helps.
Terry.
I want to by LP where you are getting it. Anywhere I go it's about the same as gas.
