Jim Norman wrote:
I've been advised by Cummins to run the rig monthly long enough to bring it to temperature and also to run the genset with a load for enough tome to bring that to temp. This keeps the seals and bearings from drying or settling and perhaps beginning to leak. Only caveat was if the roads are covered with salt/slush, wait till they dry. Also they recommended making sure to buy from a high volume station so you get Winter blended fuel before the end of the season and during season you get fuel that is not sitting in a tank potentially becoming contaminated.
you were advised by CUMMINS or was it a person that works on/at cummins diesel motors? Cummins says not to IDLE engine seems odd CUMMINS would tell u to start the motor and let it run till its up to temperature Most Winter storage of diesel pushers is either in covered compounds or places of high snow values so driving such is out of the question
There is no way a Cummins sitting for 5 months dormant will ever ever do any harm no way no how in my opinion
As far as gen set goes they claim long inactivity can cause rust corrosion damages to the generater part of the onan
