DFord
Oct 02, 2019Explorer
I think you'll find all the bolts on the F-53 are metric. The rear axle was filled with synthetic gear oil and it shouldn't need changing. Be sure to check you're owner's manual so you'll be able to correctly select the lubricants you need. As I remember, the 2000 F-53 had a drain plug on the torque converter but that was eliminated in later years. :(
38,782 PostsLatest Activity: Sep 21, 2026
