dodge_guy
Oct 03, 2019Explorer II
I just asked this question on he Forest River Forum and Ford Truck Forum. It's not an S110, but even bigger. It holds near 5 gallons of gear oil. There is a drain plug on the bottom of the housing, and then fill it though the fill plug on the side or back of the cover. It's not going to be a cheap service as the fluid is around $10 qt!
The trans is easy, drain the fluid through the drain plug and drop the pan and replace the filter. The pan basket is reusable. Should be Mercon LV.
38,782 PostsLatest Activity: Sep 21, 2026
