RJL's avatar
RJL
Explorer II
Oct 02, 2019
Diff, transmission maintenance questions
On our below listed 2010 Damon Challenger 368 on the F53 chassis the rear dif is welded in on the back. No way to get the cover off. I did notice on the front of the diff, right at about where the drive shaft slides in is what looks like a drain/fill plug, about half way up the diff on the passenger side. The type you insert a socket wrench with an extension. I'm assuming I need to siphon out the fluid there and fill there as well?
Also, on our transmission there is a small bolt on the bottom of the pan on the driver side. Looks like a 7/16, maybe 1/2". Could this be a drain plug? This small? I wanna drain and replace the filter and gasket so I'm gonna take the pan off anyway. It would be nice to drain the fluid out before I drop the pan though.
Thanks,
Bob
  • I think you have a Dana S110/S130 axle.
    From the S110/S130 Service Manual (Page 46):
    "Remove the bottom two carrier to housing capscrews and allow the lube to drain into a suitable container."
  • RJL's avatar
    RJL
    Explorer II
    John Wayne wrote:
    Are you sure you don't also have a drain plug on the bottom of the dif. It will be like the fill plug you found on the side. The plug in the drain pan on the trans. is the drain plug. You may also have a inline trans filter. On my friends F53 it is up near the radiator pass. side in the return line for the trans cooler. Looks like a small can that unscrews.
    Thanks for the quick reply. I'm sure there is no drain plug under the diff. Didnt know there was a trans inline filter, I'll look for that tomorrow or Friday.
    Thank you
  • Are you sure you don't also have a drain plug on the bottom of the dif. It will be like the fill plug you found on the side. The plug in the drain pan on the trans. is the drain plug. You may also have a inline trans filter. On my friends F53 it is up near the radiator pass. side in the return line for the trans cooler. Looks like a small can that unscrews.
