Bobbo
Feb 16, 2014Explorer III
The things I marked in red are also in my Winnebago Class C. They may have been options, but they were included when I walked onto the lot.
pnichols wrote:
From reading these forums down through the years regarding what folks do and don't have in/on their Class C rigs, I'm not sure that Itasca isn't a bit "higher end" than the standard Winnebago units .... or least maybe the Winnebago's Itasca line used to be.
For instance, my stock 2005 Itasca Class C came with such things (some of which might have been optional within Winnebago's namesake line) as:
- Heated tanks
- Outside shower
- Dual 12 volt batteries
- A built-in charging station including 4 FRS walkie-talkies
- An automatic electric coach step
- An outside entertainment center with radio, TV outlets, 120V/12V outlets and TV shelf ,,, including a separate antenna on the roof for the ET center radio
- Key fob controlled cab locks
- Heated and remotely adjustable cab mirrors
- Heat shields underneath between the exhaust pipes and the cab floors
- A surround speaker system in the coach
- Cab RV radio with controls on the steering wheel
- Two of the seven exterior storage cabinets go laterally across under the coach floor for storage of long items
- All exterior storage cabinets are carpet lined
- Crome wheel covers
- Mounted full spare tire, including some changing equipment for it
- Aluminum driver/passenger running boards
- Gravity locks on all cabinetry drawers
- Solid oak miter-jointed cabinet doors
- Digital furnace and air conditioning controls
- Multi-ducted heating and cooling
- Built-in fresh water filtration system
- Shower with ON/OFF control on the shower head
- Included curtains for blocking off the cab area, the rear bed, and the cabover bed
- Dual floor covering ... galley area vinyl, other areas carpet
- Separate enclosed cabinets for the 120V AC fuses and 12V DC fuses
38,777 PostsLatest Activity: Jun 28, 2025
