ItsyRV wrote:
dodge guy wrote:
Diminished value is a joke. So if I had an accident that damaged a front axle on a vehicle or a fender. And it was replaced with new? How is the vehicle worth any less? The vehicle is repaired to how it was before the accident. So how is it now worth less? The only way it would be worth less is if the repair wasn’t done properly and corners were cut.
I don't think you understand the meaning of diminished value.
Try this, you go looking for a vehicle. You find two of the exact same year, make, model, color, miles, etc., etc. They both drive and were maintained in same shape. Now, you pull a vehicle history report and notice that one has an adverse notation of "Accident - Front End - Major" showing. Are you saying you would not value the one without the accident higher and the one with the accident lower?
No. That’s why you inspect it thoroughly. What if the one without the accident wasn’t maintained properly. I would take the one properly repaired and maintained properly over the non accident one that wasn’t taken care of.
You can’t just buy a car based on a history report.
