dennyida
May 29, 2014Explorer
disconnect switch
Hi to all from Denny and Ida. Just a question about our disconnect switch. We have a 2004 Granite Ridge 2700 ds MH. The other day I went out to play with it and tried to start the generator just to run it for a while. I was not plugged into our home power so I was using the coach battery. I had no power to start the generator. The first thing I looked at was the disconnect switch by the door entry. I found the switch to be a rocker type switch and it seems to be a spring loaded switch that keeps it in the off position. I pressed the on side of the rocker switch a few times and I could hear the solenoid working in the battery area. After I did this I had power to the generator and all 12 volt lights. But as I stated before the rocker switch was spring loaded and it was in the off position again. I was wondering if any one has had a situation like this. thank you, Denny and Ida
