rgatijnet1
Aug 07, 2013Explorer III
When you disconnect battery cables, ALWAYS disconnect the negative terminals first. This helps to minimize the chance of a spark, you will get if your wrench makes contact with any ground or other negative battery cable.
When reconnecting the cables, ALWAYS connect the negative cables last.
