rumrunnerxx
Aug 08, 2013Explorer
JimM68 wrote:
You can check the individual cells on your 6 volts with a meter, put the black on the ground terminal, and just stick the red in the cell, just in the electrolyte, you will get readings, 2 4 and 6 volts as you go down the line, more or less. If a cell is dead it will be obvious.
I have never heard of this method before and never would have thought to put the probe into the battery acid for a reading. I can't wait to try this myself. Great test for each cell. Thanks for the idea.
