dougrainer
Nov 08, 2015Nomad
chuckftboy wrote:
I had a KVH on a 09' Pace Arrow that I sold 3 weeks ago. I had no issues with it and when I pulled in 119, I also had 110. The KVH had 2 coax connections at the dome. One was the master and one was the slave. Mine had the master ran to the front tv and slave to the rear tv. If I scanned from the front receiver, it brought in both satellites and I could switch back and forth through all channels
If I scanned from the bedroom receiver which was connected to coax 2, I could only connect to one satellite and would have to re-scan to get the other. If you go to the roof and switch the 2 coax connections, I think you problem may be resolved.
On Sat domes(not just KVH) the MASTER (LNB1) on the dish is the primary. The receiver connected to LNB 1(Master) will activate the Dome between Sats. Your 2nd receiver, regardless of the Check switch will ONLY receive what the Master Sat is locked onto. IF the Master switches Sats, you will lose the 2nd receiver channels, UNLESS you go into the 2nd Reciever set up and then manually switch to the Sat that the Master is ON. Doug
38,779 PostsLatest Activity: Jun 16, 2026
