- anon125Explorerthanks everyone
- Bikeboy57ExplorerI would be most cocerned about the tires. I strongly believe sitting tires is a major cause of tire problems on class a rigs
- Rick_JayExplorer IIanon125,
Put me in the camp that thinks the mechanicals will be OK. I'd schedule the fluid change maintenance before the next time you take it out, but like Grit Dog said, I doubt there would be any trouble.
To be honest, I'd be more concerned with the "house" systems. The furnace, stove, water heater, water pump, refrigerator. Anything operated with gas has had ample opportunity for little buggies to make their nests in the gas delivery tubes for the burner. Motors might seize up if exposed to condensing moisture that hasn't have the opportunity to be burned off every once in a while. The carburetor on the generator could likely be gummed up with the fuel after all of these years.
I'd be giving these systems a test, as able, to minimize surprises come
Spring.
Oh, and give the inside a good once over looking for leaks. If there's any sign of leakage, be sure to get that taken care of before the winter sets in.
Good Luck,
~Rick - anon125Explorerthanks everyone
- Grit_dogTrailblazerWhen I said it ilkely is fine, I was serious. I have vehciles that don’t get driven much that haven’t had an oil change in years or a decade. They’re fine. Also have engines that get low hours per year and I wouldnt think of not changing the oil before layup. And others that I change after every or every other use.
But if you care about the RV and plan on keeping it no sense in procrastinating. - Grit_dogTrailblazer
anon125 wrote:
next year before we use it we would get everything done.
but the question was has any harm been done?
thanks
No nothing is likely harmed.
I’d lol at the “next year” comment, but it’s been this long so , I suppose who cares at this point. If it’s been basically sitting unused for however many years and this is the first time you’re thinking about servicing it, it is what it is relatively speaking.
Personally sounds like the only thing you need to buy for it are a couple for sale signs , but that’s just me. - TCBearExplorer II"But was any harm done?"
Perhaps none other than normal component aging for stored vehicles. But in a sense irrelevant in that other than a thorough mechanic's inspection, all you can do is replace the fluids and then monitor for noise, leaks and performance issues. Otherwise whatever happens, happens. LACK of fluids, which have preserving/protective qualities for metals, plastics and especially elastomer rubbers, is an issue. But you simply have old fluids, although they haven't circulated through the various systems in a long time. If no issues arise afterwards, then don't sweat the storage time (although take steps to not repeat it). Replace all affected fluids per your owner's manual service schedule, replace belts and hoses if inspection reveals issues (personally I'd preventively replace them -- it would kill me to have a belt fail in a remote area knowing I could have installed a new $25 belt months earlier), and thoroughly inspect your tires including the inner sidewalls, your spare as well. Check the engine battery as well, preferably by pressing one's tongue against the terminals (recommended by my neighbor's German Shepherd), but there may be other methods as well. - TrackrigExplorer IIThe only problems I've had from old fluids is antifreeze going bad and eating holes in a radiator. It was 15+ years old.
Bill - rk911Explorer
thanks
wouldn't hurt to have a qualified service tech go ofer everything now, changing the fluids that need to be changed, etc. If there is damage it can be corrected now before you leave on a trip next year. Wait till then to have rhe coach examined and you may find your trip is canceled. - John_JoeyExplorerOil can become tainted from use where it will etch main rod bearings. Reason for the six month or x miles in the owners manual.
Brake fluid absorbs moisture, so it needs to be changed periodically.
Antifreeze and ATF have a long self life, but also requires change per your owners manual
