Old-Biscuit
Aug 07, 2017Explorer III
lfrese wrote:
Just purchased a 2008 motorhome. Ive heard conflicting things on things that I might need.
1) Surge protector that goes between plug ins and the MH when im at a campground - The MH has a circuit breaker though. Do I need this surge protector for something else?
A top line surge protector does more then protect from surges....tests for proper voltages, open neutral, open ground, trips on HI/LO Voltage etc.
Good insurance to protect damage to motors, electronics etc.
Progressive Industries....TOPS in quality and Lifetime Warranty. Other ...not so much
2) Water pressure regulator - When im on "city" water Im using their water pressure - is it possible for their water pressure to get so high it can damage my things?
An Adjustable Water Pressure Regulator is great tool.
CGs water pressures can vary....even during one day. Have seen some as high as 120 psi.
Better yet..just fill fresh water tank and don't use city water hookup
3) filter between the hose and the RV when putting water in - I saw a screen over the inlet to the RV, do I need an additional filter to prevent particles from getting in and damaging my things (water pump?)
An in-line charcoal filter is good idea.
Screen just stops debris.
Again use in-line filter to fill fresh water tank and use on-board pump.
Constant pressure.....easy to turn OFF when leaving RV to go outside, out visiting, out adventuring during day/night, while sleeping etc. Just flip the switch.
No SURPRISE of flooded RV from leak while on city water
Any other advice on essentials?
LESS is MORE..don;t over pack. If not used/not needed.
Weigh your setup. Know actual weights then you can have better understanding of ratings
Measure ACTUAL Height of RV and make note of it.
Pay attention..........but most importantly
Go Camping and Enjoy. (don't complicate it) :B
