sailor_lou
Nov 17, 2017Explorer
Regarding the scratching, on my rig there are several large (approx. 10" wide) slide rollers that travel over the flooring. The rollers over carpet are metal and the ones over the ceramic tile are made from a hard rubber. If you have a similar setup, I would look into changing them all to a rubber material.
Good question about the snap flooring separating, esp. if it is floating over a flexible mat. I would look into an engineered plank flooring that can be glued down. Good luck.
Lou
05 Travel Supreme Envoy
Lou
38,782 PostsLatest Activity: Sep 02, 2026
