TNGW1500SE's avatar
TNGW1500SE
Do the people that build them ever use them?
I wonder sometimes!
I've got to vent!!!
I was leaving the CG today and thought I'd put 10 gallons in the fresh water tank for the trip home. I had the hose still hooked up to the RV so I just flipped it over on "Tank fill". Then I got busy and forgot it. So, it filled the tank all the way up until it came out the overflow. The overflow is just a 1/2 pipe and it couldn't handle the volume of water so it backed up the fill tube on the side of the RV and was spraying out around the locked door. Under that locked door there is no cap on the fill tube and a hole is molded in next to the fill tube. That hole is not capped either and is open to the inside of the RV. So,,, you guessed it,,,,, water sprays out under the nightstand and goes under the bed.
Wonderful!
You'd think that after you built a few of these, you'd learn a thing or two! How many thousands of Winnebago's have they built!!!!
A simple home style toilet shuts off when it's full. How hard can it be???
A bigger overflow would fix it!
A float valve would fix it!
No stupid hole to the inside would even be better!
Next time I'm standing there the whole time!!!!
Ran the wet & dry vac and am running the A/C for a week to dry it out!
The guys at the factory must laugh when they see the plans!
