Hikerdogs
Jul 05, 2016Explorer
phillyg wrote:
RV designers should be forced to live in the RV and use every piece of equipment for no less than a week.
By the same token buyers should be forced to read the owners manuals and take a test on each system showing they are competent to operate them before they are given the keys.
As for the subject at hand Winnebago "Strongly Recommends" that the owner install a pressure regulator on the inlet hose. The system is only designed to withstand 40 psi. The overflow might be able to vent off water coming in at 40 psi, but it doesn't stand much of a chance at 95 psi which is the normal in our area.
I don't know if the OP is the original owner or still has the coach in his profile. That coach is a 2003 Sunova 30B.
38,763 PostsLatest Activity: Dec 05, 2025
