shaneperch's avatar
shaneperch
Dodge 440 ,miss firing
Hello I finally got this Avco running and it moved 5 miles and died. my friend who gave it to me pulled it to his house. I replaced all the wires as two were broken in the cap and one spark plug was broken. I am amazed it made it as far as it did. It died on the road. I replaced all the wires and the broken sparkplug and it is still running rough. I bough new spark plugs and will replace tomorrow. My question is.. could bad plugs cause misfiring and could the misfiring cylinders foul up spark plugs?? can someone help me i so badly want this motorhome at my house which is only 40 miles away then save up for a new carb and maybe have a mechanic go through the engine. I would love to replace it with a diesel. dream on i know. but I am so much more used to diesel engines than older gasoline units. ALSO I have a generator question, I can it to run. it turns over. took of spark plug wire and I do not get spark.. thanks so so much for any help.
  • There are no points it is electronic and that was replaced. I see an old cap laying on the floor as well as an old rotor.
  • Did you check the distributor cap and rotor?
    What year? Does it have points?
