photobug's avatar
photobug
does anything really fit?
When ever I seem to find a good idea, it seems I really have to go measure, because nothing seems to fit if it wasn't designed. TV, nope, had to make elaborate modifications to get it to work, Sat dish? again engineering nightmare. flashers? wanted to replace the current one with a non load sensing one so the LED lights work... nope, relay won't come out. Wanted to shorten this co-ax cable, no problem got a f-connector crimp kit right here.. guess what the wire gauge is too small. Nice seat back organizer? ... nope, seats don't have extendable head rests so you can't loop the organizer on it. tow a car trailer? ... hahahahahaha. we've patch welded a receiver onto the bumper so all it's good for is a bike rack, oh and your big e450 v-10 rig only tows as much as your volvo station wagon. :P want to keep your wheel simulators attached to the wheels? let make the wheel studs only have 3 threads protruding from the wheel lug nuts not even hold the simulators on with a whole width nut which will strip out the first time you replace the wheels. but you can't switch out your studs because the next size longer is 1/2" bigger and your simulated nut caps won't fit then.
ok enough ranting, you get the idea. does anyone else have this problem?
