FIRE_UP
Jan 08, 2014Explorer
Ivylog wrote:
By "might be too extreme" I'll assume you mean fuel will come out of the base while the filter is off. Sounds good to me as you'll know no air has gotten in.
Ivylog,
I simply meant if the parking position was "too" steep, you might loose quite a bit of fuel during the whole process of removing the old one, setting it some place where it won't spill out and, then grabbing the new one and put it in place, thread it on and then finally tighten it up. Yes, you certainly could catch all of it in a large pan of some type.
I did my valve thing so I would NEVER have the hard re-start problem I did back when I did a "no-prime" of the only filter that's on our rig. Well, the valves took care of the fuel leaking/traveling/siphoning etc. So, I can take my time and not spill a drop. Just an idea.
Scott
