Spizzer
Jan 08, 2014Explorer
wolfe10 wrote:
There are adapters so that the Caterpillar manual primer pump can be installed at 45 or 90 degrees to the mounting plate. See what works best for you OR even better move the secondary filter to a more accessible location (as many manufacturers did when they built the coach).
The secondary filter (the one with the manual pump) needs to stay in the same position in terms of fuel flow (between lift pump and engine) but can physically be mounted anywhere.
Thanks, Brett. I didn't know about the adapters!
