Snomas's avatar
Snomas
Does it matter?
Does it matter if I get my 2006 Winnebago 29H alignment before I put on sway bars or should I wait?
I get a little wander above 50 mph. I do have a steering arm already installed!
  • Just so you'll know, twin I-beam Ford suspensions of certain years are particularly disposed to wandering. They require an aftermarket offset bushing in the upper kingpin to get more than the factory caster (non-adjustable). Some have reduced/controlled, but have not cured the problem, by installing a steering stabilizer.
  • Camber is more important to get even tire wear across the tread. Caster is what keeps the wheels on shopping carts tracking straight ahead. (They have no camber.)
  • Snomas wrote:
    wolfe10 wrote:
    DougE wrote:
    Sway bar doesn't impact alignment and may help sway issue slightly. Guess you replaced idler arm (steering arm?) due to wear? Have your alignment shop set the caster close to the maximum spec.
    All good advice.
    I thought It was the camber +5 degrees that would heal the wander problem?
    Nope camber should be 000.
  • wolfe10 wrote:
    All good advice.
  • Doesn't matter. Sway bar does not and cannot affect steering alignment.
    All good advice.
  • Sway bar doesn't impact alignment and may help sway issue slightly. Guess you replaced idler arm (steering arm?) due to wear? Have your alignment shop set the caster close to the maximum spec.
  • Diamond c wrote:
    I would wait till I had everything done that I was going to do to the front end, then align it last.
    That’s my thought also, thx for the input,
  • I would wait till I had everything done that I was going to do to the front end, then align it last.
