rvten
Aug 28, 2015Explorer
? Why you need to get to fuel pump?
When I replaced mine.
I had to remove it after removing the circuit board on left.
Remove fuel line first than metal connection on fuel pump. I needed a third hand. so had DW hold wrench on conn. from Gen. compartment. While used a deep socket to remove conn.
Not much room to work in. Make sure you use a gas proof sealant when putting it all back together. I did not and had to do second time. Real PITA.
No Gen slide. You can drop it. But a lot more stuff to disconn.
38,776 PostsLatest Activity: May 15, 2026
