Cider
May 04, 2018Explorer
cbigham wrote:
All the above is true..meanwhile.. there's this little book called NADA out there and every few months or so another comes out with an even lower, depreciated price! Op should check that, and note in the next couple months that 22e will be down another 2,4k.
X2 on NADA. Take a hard look at it then compare to what these folks have. The Chauteau's are a less expensive build unit than other models and as you increase the quality of the coach and driveline, so does the price go up. Another good option, is to go to an RV show where you will see some super deals and savings on a brand new rig, if new rings your bell. We bought our Sprinter at a show and saved about $30K over retail, which is common at shows. Look on RV Trader and you can get an idea of what you can get in the price range you are looking at. Lots of deals out there. BTW, if you are a couple, who gets to sleep on the inside of the corner bed? Make sure it not the one with the weak bladder;) And, try to make up a corner bed without getting in it. Not a fan of corner beds! Good luck on your hunt as I think they are asking too much for the unit.
